Hi guys, me again with what is probably another naive newbie question. When I set up my torch today, as soon as I opened the oxygen regulator, oxygen flowed freely through the torch. This happened regardless of how I adjusted the torch valve or the regulator. I didn't feel like trying to light the torch under those circumstances, so its back in the box for the time being.
Does anybody know of a solution to this? Is it more likely to be a fault with the valve or user error? I don't think it's wear as the torch has barely been used and has been stored quite fastidiously.
Thanks in advance, any help anyone can give me is very much appreciated
Not seen a proper cutting torch with the 3rd valve - only on a cutting attachment fitted to a welding torch ( like a BOC saphire ) can the OP post a picture so we can figure it out ?
Glad you have it sorted & don't worry if you think a question is daft - we all start somewhere & have to learn - no one is born an expert ! only one guy on here we know of works for NASA - the rest of us are just mortal & learn by mistakes over time !
