I got a track torch on auction from a school district. It uses three hoses, Red, Green and Black. The red and green hoses go to the Oxy and Ace; no problem.
Any advice on what I should/can use with the black hose; it goes to the center larger opening in the cutting tip. My thoughts are,
1) My with a different regulator set at a higher pressure, Oxy.
2) CO2 with it's own supply.
3) Filtered air from my compressor.
If any one has observed the standard gas for the black hose/center tip opening PLEASE let me know.
Thanks, Paul
You should be able to find info from the manufacturer. If you know the model number of the torch and the model of the tip. Depending on the torch body and the head it may be any one of those gasses, or just one.
- Farmwelding
Would you contact Miller on that since they bought out Airco?Poland308 wrote:You should be able to find info from the manufacturer. If you know the model number of the torch and the model of the tip. Depending on the torch body and the head it may be any one of those gasses, or just one.
Here is a listing of someone on eBay who apparently deals with these torches a lot.
https://www.ebay.com/i/162714882197?chn ... 0373804497
Maybe a quick email to the seller.
Edit
http://www.bluerocktools.com/content/CG ... Manual.pdf
Here is a manual for a different brand, but it lists two of the hoses for oxygen. Probably so you can get enough flow and control for both actions of the cutting head.
Edit
I run a " normal " Boc Pug & an old line following optic profile cutter - both use the 3 line head as in the picture below - the hoses go to the mixer valve block & the two oxy lines have separate valves to adjust flame & cut flow but are joined to a common supply so there are only two hoses going to the cylinders - I guess for certain specialist applications a different gas could be used for the cut jet but I have never seen this done or really see why it would be necessary.
- BOC Pug.jpg (158.75 KiB) Viewed 1537 times
