- Chips O'Toole
Today I used a Walter Enduro-Flex flap wheel to shape some things I was welding. I love these wheels, but it would be nice to have something in a finer grit. The ones I have are 40-grit. What's the best step up, for a better finish and more control? Should I try 80 or go all the way to 120?
- Chips O'Toole
Thanks. That sounds fine.
Are these things useful on 6" grinders, or is it better to stick with 4.5" for easier control?
I use 40 or 60 most of the time. Unless you are working your way to a fine polish then don’t go as fine as 120. Except for thin metals then that fine of a wheel becomes necessary.
Really depends on what your grinding on, I only have a 4.5" grinder, but if you're doing thick wall structural work with a lot of beveling then a 6" grinder would be "more better"
I do have a 120 flap wheel which is nice for a fine finish, but for what I do it's mostly not needed
- Chips O'Toole
I found a good deal for 80-grit wheels on Ebay, so now I have 10 of them.
SCsoldier04
- SCsoldier04
Go check out benchmark abrasives. Not the highest quality pads but if you are just using at home and what not they are awesome.
BillE.Dee
- BillE.Dee
Have any you all found a decent flap wheel to cut aluminum? I know that putting the right weld down will avoid all the grinding and cussing....BUT, I've been working on restoring some parts and looking to grind without clogging the wheel.
