Phil
    Wed Nov 04, 2015 8:49 pm
    North West Indiana Chicago area
I want to try and repair this cast iron exhaust manifold from a 1971 477ci Ford Super Duty dual axle grain truck. The previous owner attempted a repair while the manifold was still bolted to the engine. We tried but could not locate replacement manifolds or headers. After the manifold was removed it was sand blasted.
The 3 types of tig filler wire I considered to use were: Aluminum Bronze, Crown Alloys Royal 55/45-10 copper - nickel, or a new product by Davbro Inc. EZ WELD tig wire.
The manifold was broken in 3 parts and also has a vertical crack in it.
Has anyone attempted a repair like this? and what would be the method that would be most successful to use.
I was unsuccessful trying to tig this manifold. The excess silicon and carbon in the manifold would pop off and coat the tungsten. What I discovered after drilling a hole at the top and bottom of a crack was the shavings coming off the drill bit looked like black granules of gunpowder no metal spiraling up the bit at all. I think this manifold had a lot of slag in the molten metal when they poured it into the mold during manufacturing.
I ended up brazing it with Crown Alloys 120 nickel/silver brazing rod.
Bolt lug brazed back on
There was a large hole in the manifold so I brazed a 1inch by 1 3/4 inch plate on the inside of the manifold before I reassembled it.
Finished manifold
Finished manifold
After all the work and brazing, the end exhaust port is warped up 1/8 inch, so when we bolt it back on the engine a shim will be needed to get it to seal up. If nothing else I learned a lot from this project. :oops:
warped now have to shim it
I guess I will have to learn how to make a set of headers :|
Miller Dynasty 200DX Argon/Helium Y in
Hypertherm Plasma cutter
oxy/acetylene Harris, Smith, Meco Midget
Wilton vertical bandsaw
Rockwood Drill Press
Dayton 8" bench grinder
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
phil welcome to the forum.
i haven't repaired cast with TIG
but I'm sure other members will be
able to give you advise if you are
patient. showing what you need to repair
will make it easier to get answers.
Mike
    Mon Dec 06, 2010 1:09 pm
    Andover, Ohio
Welcome to the forum Phil.
M J Mauer Andover, Ohio
Linoln A/C 225
Everlast PA 200
Welcome. This is a thread that was here not to long ago similar to your question. http://forum.weldingtipsandtricks.com/v ... t=Seasoned
