Howdie from Montreal, Canada!!
Posted: Wed Nov 05, 2014 1:11 am
by georgie
Hey all! New here. Ive got about a year of playing around with tiggin. Mostly on stainless 316 as i work in a textile plant and most of the machines are dying machines.
What they do is that fabric runs in them via reels with mechanical seals because the machines are mostly under pressure. The heating source is steam. The main chemicals that run in these machines are Salt, Soda Ash, Costic Soda, Peroxide, Acetic Acid to name a few. Some of the machines are not under pressure.
Most of my welding experience comes from modifying these machines to fit.into our tight plant. Most of the machines are from the late 70's, so they have been used ALOT!! So ive cut alot pipe and rewelded them shorter to accomodate the different angles needed.
So thats it, glad to be on this forum!
Ohh! BTW thanks to Jodis videos ive been able to get to this point and consider myself a descent tig welder!
Re: Howdie from Montreal, Canada!!
Posted: Wed Nov 05, 2014 10:28 am
by Mike
welcome to the forum.
Posted: Wed Nov 05, 2014 8:00 pm
Welcome, georgie,
It sounds like you'll be able to share as much as you can learn here!
We build this forum on the experience of it's members, so that the forum, as a whole, becomes a welding expert... So that any question can be asked here, and someone will have an answer.
Posted: Wed Nov 05, 2014 10:20 pm
by Superiorwelding
georgie,
Glad you are here as well! I am interested in seeing some pictures of the machines and modifications, if you can share them.
