RookieWelder
    Tue Oct 14, 2014 8:33 am
    Raleigh, NC
Hello, all!
I've been lurking a while and decided to finally sign up and say hello. I've recently decided to teach myself how to weld from a hobbyist's point of view. Wanting to learn to weld has been with me since my days in High School Metal Shop. I never could strike and hold an arc with a stick welder back then, despite trying over and over, managing to stick the electrode to the bit of steel I was hoping to lay a bead down onto. The Shop teacher finally suggested I go over by the forge and cast some more fishing sinkers...
I picked up some safety gear and a Harbor Freight MIG 170 welder - I figured that if I found out that metal working wasn't for me, I wouldn't have too much dough invested. So far, I've only used it with flux core wire, and I've been able to actually produce a couple of decent looking welds. I also managed to put this simple welding table together:
It's not perfect, but it's getting the job done!
After I developed a bit of mastery with the small MIG welder, I picked up an Everlast PowerArc 200ST stick welder and 5 lbs of 6013 rods. I'm striking arcs and running beads on 1/4" plate, so I hope my fishing sinker casting days are behind me now.
Dwight
Welcome aboard, Dwight,
We all start somewhere, and that welding table suggests you won't be casting sinkers here...
And, here, you can ask anything you want and get a serious answer.
Mike
    Mon Dec 06, 2010 1:09 pm
    Andover, Ohio
Dwight welcome to the forum.
M J Mauer Andover, Ohio
Linoln A/C 225
Everlast PA 200
