Mikechallgren
    Thu Jul 17, 2014 10:25 pm
    Van Nuys, California
Someone tell me about Pyrex gas cups...please..
Mike the wire airplane guy http://www.wiresculptor.net
Mike
    Mon Dec 06, 2010 1:09 pm
    Andover, Ohio
Welcome to the forum.
M J Mauer Andover, Ohio
Linoln A/C 225
Everlast PA 200
gamble
    Mon Mar 07, 2011 1:10 pm
Mikechallgren wrote:Someone tell me about Pyrex gas cups...please..
It's a gas lens kit with a clear cup...
    Sat Jul 06, 2013 11:16 am
Mike,
I'm not sure what you want to know but I'll let you know what I know. They're a type of gas lens in the general sense, they are large enough to offer good coverage on most metals with some oversized ones for specialty alloys. They can't take as much heat as alumina and probably the same amount as ceramic. They don't like to be banged around at all.
Their being clear is a great benefit, unless like me, you occasionally dip your tungsten and then they're less than clear from the smoke.
If there's something in particular you want to know you'll have to be less vague with your question.
gamble
They melt at 500*
Mikechallgren
Mike wrote:Welcome to the forum.
Thank you, I look forward to the information...
Mikechallgren
Thank you!
Mikechallgren
Braehill wrote:Mike,
Thank you. I think I'd like to try it for the visibility aspect. Yes, I will probably 'smoke it up', but hopefully seeing the weld puddle will lessen that puddle 'leaping' up on my electrode...
Mikechallgren
gamble wrote:They melt at 500*
Thank you!...
rahtreelimbs
    Mon Jun 14, 2010 10:39 pm
As long as you don't walk the cup you should be ok. Like everything else they have advantages and disadvantages. th
They have a place!
gamble
With a pyrex cup the stick out should be 5-6 times the diameter of the tungsten.
Also the Oring will melt at 500* as well.
And when using it on AC don't use more than 30% EN or it puts too much heat into the tungsten which heats up the glass
Mikechallgren
They have a place!
Thank you. Gathering data from you and others helps me in my quest to become a better welder, I appreciate your input!
Mikechallgren
gamble wrote:With a pyrex cup the stick out should be 5-6 times the diameter of the tungsten.
Thank you for your time and your input, I appreciate the information.
Mikechallgren
They have a place!
So as long as I use in and out I should be ok? How much stick out should my electrode have?
Thank you for your time an information,
gamble
5-6 times the diameter of the electrode. Just don't use it at 300amps and it will be fine.
