Hi from NY
Posted: Sat Nov 09, 2013 11:20 am
by tommays56
I bumped into the videos when trying to figure out something and found them helpful
For work i repair SS mixers
For a hobby i build some fairly nice bicycles
Re: Hi from NY
Posted: Sat Nov 09, 2013 3:29 pm
by jwmacawful
howdy neighbor!
nice pics. i for one like to see how the other guy's are holding it down! those mixers aren't bicycle powered are they??
Re: Hi from NY
Posted: Sat Nov 09, 2013 3:32 pm
by jwmacawful
have you ever built a recumbent type bike??
Re: Hi from NY
Posted: Sun Nov 10, 2013 8:31 am
by tommays56
For racing i have done some tandems
For fun we built a good bit of junkyard wars rules triples and tandems with one rule you had to find everything from the garbage ;)
Re: Hi from NY
Posted: Sun Nov 10, 2013 10:38 am
by jwmacawful
what are the bike frames made of and what process are you using to weld them?
Re: Hi from NY
Posted: Mon Nov 11, 2013 9:57 am
by Mike
Welcome to the forum.
Re: Hi from NY
Posted: Mon Nov 11, 2013 7:56 pm
by tommays56
The tandems are made from a mix of .035 wall chrome moly tubing and tandem specific oval tubes as weight is not as much of factor
All my road frames are made from Columbus Nivacrom EL ( extra light ) and the material is sold in a complete set to build one frame
The EL tubes are triple butted with .027 ends and most of the tube is .015 wall for light weight and it is about twice the strength of chrome moly BUT it is really easy to screw it up
The first time you pick up a piece of material it is shocking how light it is compared to the same thing in .035
When they were building the Concord they developed a special new steel for landing gear parts ( Nivacrom) and Columbus ending up with the bicycle end of it
I build everything with a oye acetylene torch and a thin flux free bronze brazing rod as you need to flux before you heat
I use a torch because i like the look of fillet brazing and i am good at it as the metal is so thin
All of my TIG work is on really thick material so it is hard for me to dail back to .027 wall :)
Re: Hi from NY
Posted: Tue Nov 12, 2013 5:29 am
by jwmacawful
thanks for the 411. i do a lot of biking and i often thought about building a bike. it was good to see someone who actually does make them.
