Thank you Jody
Posted: Thu Dec 13, 2018 1:23 am
When I started in engineering oxy/acetylene and stick welding were the go to options for manual welding, but later everyone said MIG was easier. So when I returned to home welding I bought a cheap 150 amp MIG machine, figuring that as a welder MIG would be a doddle. But not so. I found MIG frustrating to say the least, with very inconsistent and poor welds.
Then I found Weldingtipsandtricks.com. Yes it was inspirational marveling at Jody's ability to consistently lay down beautiful MIG and TIG welds but it frustrated me even more. Until I finally listened to Jody and realized that MIG welding is mostly about the machine settings. I then started to put into practice Jody's most basic of tips, things like measuring the actual wire speed of your machine. So simple and yet brilliant. I now use the Miller app for wire speed and the machine's table for a voltage start point. I have cleaned my welding lens so I can actually see through it, added more lighting and added cheat lenses to my helmet, brilliant. Now I can see the weld clearly and carefully guide the gun tip as I work.
So thanks to you Jody I can now lay down a good looking weld of the required size with good penetration on a consistent basis, quickly and efficiently. Brilliant and much appreciated.
