How to minimize etching/frosting on aluminum tig welds
Posted: Fri Mar 02, 2018 10:34 pm
by Tbottwelds
Just looking for some advice on how to minimize the etching or"frosting" around my aluminum welds.. I have an aluminum hood that I will be doing next week and would like the corners to have minimal etching as it doesn't get painted or anything.. It's 1/8" 6061.. I am using a snycrowave 250 cleaning action usually is around 5.. my company provides pure tungsten so can't do much about that and have convinced them to switch once I run out... Any tips would be appreciated
Re: How to minimize etching/frosting on aluminum tig welds
Posted: Fri Mar 02, 2018 10:36 pm
by MinnesotaDave
If your balance is turned down as much as practical, then increase amps to weld faster.
Low amps leads to slow speeds - that increases the size of the etching line on each side.
Pure tungsten doesn't bother me any - but I understand that a lot of guys don't like it.
Posted: Fri Mar 02, 2018 10:57 pm
If you crank up the frequency, the etch zone will be thinner as the arc narrows.
Posted: Fri Mar 02, 2018 11:16 pm
by MinnesotaDave
cj737 wrote:If you crank up the frequency, the etch zone will be thinner as the arc narrows.
Correct me if I get it wrong, but I don't believe any syncrowave 250 will have adjustable frequency output?
Pretty sure that's only on an inverter based machine.
Posted: Sat Mar 03, 2018 6:30 am
by Tbottwelds
Correct it's set to 60Hz so nothing I can do there
Posted: Sat Mar 03, 2018 7:28 am
by Louie1961
I usually weld 6061 aluminum with a balance of 7 or 8 assuming it is cleaned well before hand. start there
Posted: Sat Mar 03, 2018 7:55 am
MinnesotaDave wrote:cj737 wrote:If you crank up the frequency, the etch zone will be thinner as the arc narrows.
You are not, I am unaware.
(I did say, "if you...")
Posted: Sat Mar 03, 2018 4:04 pm
by 5th Street Fab
You can switch to number 5 standard collet body cup and run your gas flow at 10-15 cfh. Lower cfh and small cup helps narrow the etch zone. But you can also scotch brite it afterwards.
Sent from my XT1635-01 using Tapatalk
