Tbottwelds
    Sat Dec 09, 2017 4:43 pm
    Elmira,Ontario
Just looking for some advice on how to minimize the etching or"frosting" around my aluminum welds.. I have an aluminum hood that I will be doing next week and would like the corners to have minimal etching as it doesn't get painted or anything.. It's 1/8" 6061.. I am using a snycrowave 250 cleaning action usually is around 5.. my company provides pure tungsten so can't do much about that and have convinced them to switch once I run out... Any tips would be appreciated
    Sun Oct 27, 2013 10:57 pm
If your balance is turned down as much as practical, then increase amps to weld faster.
Low amps leads to slow speeds - that increases the size of the etching line on each side.
Pure tungsten doesn't bother me any - but I understand that a lot of guys don't like it.
If you crank up the frequency, the etch zone will be thinner as the arc narrows.
cj737 wrote:If you crank up the frequency, the etch zone will be thinner as the arc narrows.
Correct me if I get it wrong, but I don't believe any syncrowave 250 will have adjustable frequency output?
Pretty sure that's only on an inverter based machine.
Tbottwelds
    Elmira,Ontario
Correct it's set to 60Hz so nothing I can do there
    Wed Jan 22, 2014 12:00 am
    Connecticut
I usually weld 6061 aluminum with a balance of 7 or 8 assuming it is cleaned well before hand. start there
Multimatic 255
You are not, I am unaware. ;) (I did say, "if you...")
    Sun Jan 15, 2017 1:08 am
You can switch to number 5 standard collet body cup and run your gas flow at 10-15 cfh. Lower cfh and small cup helps narrow the etch zone. But you can also scotch brite it afterwards.
Sent from my XT1635-01 using Tapatalk
