pgl2389
    Sun Aug 06, 2017 6:01 pm
Can anyone help me? I am using pure argon have tried all different flow rates and angles. High and low current settings. Grinding the tungsten to a point. Little annoying because when using the tig welder at work I get very very good welds
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
Welcome
You most likely have some kind of gas issue. Check that you have welding grade 99% pure argon and if possible check your set up with a bottle of gas thats known to be good.
And soap all your connections for the gas. When you start an arc can you hear the gas flowing at all?
pgl2389
Checked for leaks and gas coverage, I am a little suspicious of the gas, it's from a supplier I have never used before. I'm going to take it to work today and hook it up to the machine I usually use and see what happens.
Mike
    Mon Dec 06, 2010 1:09 pm
    Andover, Ohio
Welcome to the forum.
M J Mauer Andover, Ohio
Linoln A/C 225
Everlast PA 200
rahtreelimbs
    Mon Jun 14, 2010 10:39 pm
Any chance your employer would allow you to take an argon tank home for a try? This would tell you straight away.
