ZachCTCWelding
    Fri Oct 28, 2016 10:35 am
When I go to strike an arc the rod keeps getting stuck. Does anyone know something I can do to help prevent that?
    Fri May 27, 2016 11:00 am
    Atlanta, GA
Don't try to strike an arc with a cold rod. Touch the rod firmly to the work stock and hold it there for about 5 seconds. This will preheat a bit of hell fire into the rod. Now lift off and try to strike an arc. This is similar to the hot start feature on some welders but it often works better. If you're working with really cold metal then you may need to preheat the work stock with a torch.
Raymond
Everlast PowerTIG 255EXT
What kind of welder are you using? Even some of the new inverters don't like to run 6010. Also what amps are you running? And what size rod?
    Sun Oct 27, 2013 10:57 pm
ZachCTCWelding wrote:When I go to strike an arc the rod keeps getting stuck. Does anyone know something I can do to help prevent that?
Are you a new welder? A lot of new people have this problem.
Scratch quickly like a big stick match. Welder has to be hooked DC+
Also, always provide all information when asking for help - makes the process go faster.
Mike
    Mon Dec 06, 2010 1:09 pm
    Andover, Ohio
Zach, welcome to the forum.
M J Mauer Andover, Ohio
Linoln A/C 225
Everlast PA 200
