maddison33
    Wed Sep 14, 2016 2:47 pm
Good afternoon all! I'm a custom home builder in need of a welder in the Little Rock, AR area that is skilled in CAST IRON. Will need to weld some brackets on the back of reclaimed (or new) firebacks. Using them in a backsplash behind the range. They will not sit on the countertop, but be mounted within the decorative tile...and at 60-80lbs each, need some brackets to guarantee they do not fall OFF the wall. ;) I have a couple links below to check out the product: (RECLAIMED) https://www.firebacks.net/arms-of-franc ... n3003.html OR (NEW) http://www.woodlanddirect.com/Fireplace ... n-Fireback Can anyone help? Thank you so much in advance!
