Can anyone help me? I am using pure argon have tried all different flow rates and angles. High and low current settings. Grinding the tungsten to a point. Little annoying because when using the tig welder at work I get very very good welds
- 20170806_221211.jpg (36.64 KiB) Viewed 748 times
Welcome
You most likely have some kind of gas issue. Check that you have welding grade 99% pure argon and if possible check your set up with a bottle of gas thats known to be good.
rahtreelimbs
- rahtreelimbs
Any chance your employer would allow you to take an argon tank home for a try? This would tell you straight away.
