    Thu Mar 27, 2014 5:02 pm
    Danville Pa.
Hi Guys
New guy from Pa. I've been watching the tips and tricks and found this forum. I have a hot rod shop and do my share of welding. I really need to focus more on my aluminum. I will be doing more 3003 H14 , and most will be but welded. Now I'm not having to much problem with that, but working on keeping it from cracking. Most of the problems come from after I wheel or power hammer it seems to crack next or sometimes right on the weld.
Well off to read as much as possible :)
Hot Rod Sheet Metal Fab & Shaping
Miller Syncrowave 210
Millermatic 252
Lincoln SP200
Hypertherm 45
Airco 300 Tig
    Thu Jan 24, 2013 10:13 pm
    Eddy, TX
ProMetalShop,
Welcome to the Forum! Read until your hearts content! If you are forming/hammering on your alum and you are using the TIG process, you will have a lot of trouble with cracking. I would suggest to gas weld the joints.
Here is a video featuring Ron Fournier on why and how to use the gas welding process.
https://www.youtube.com/watch?v=nmXXE2Os8N0
    Danville Pa.
I've been gas welding forever probably since the early 70's, however I would like to get the tig to work. I get some welds I can wheel and planish and others simply split. But I'm stubborn, I'd like to make this work. :D
Millermatic 252
Lincoln SP200
Hypertherm 45
Airco 300 Tig
    Wed Oct 23, 2013 3:30 pm
    Palmer AK
Welcome Mate, and good luck... :D
~John
Mike
    Mon Dec 06, 2010 1:09 pm
    Andover, Ohio
Welcome to the forum ProMetalShop.
M J Mauer Andover, Ohio
Linoln A/C 225
Everlast PA 200
    Danville Pa.
Thanks Guys for the welcome. :mrgreen:
Millermatic 252
Lincoln SP200
Hypertherm 45
Airco 300 Tig
paul_s
    Thu Feb 06, 2014 10:04 pm
    SW Florida
Welcome to the forum.
