h7m1
    Wed Jul 25, 2018 11:34 pm
Up for sale is in excellent working Fremco MicroFlow Touch Fibre Blowing Machine, well handled and maintained.
The Fremco Microflow is the natural choice for effortless FTTH installations. Its compact size and dual voltage usage sets it apart from its few competitors in the market.
It has been designed to blow fibre cables from 0.8-6.5mm into tube sizes 4-16mm at speeds of up to 90m per minute over distances up to 2.5km.
Fibre blowing machine for FTTH fibres (EFBU) and micro cables up to 6.5 mm
More about the machine:
Specifications
Item No.: ..........................................................................101-10051
Cable diameter...............................................................0.8-6.5 mm
Duct diameter:....................................................................4-16 mm
Blowing distance1:.................................................... Up to 2,500 m
Blowing speed2:......................................................Up to 90 m/min
Recommended pressure and airflow2:.....................................8-16 bar (200-500 l/pr. min.)
Weight:.................................................................................... 11.7 kg
Length:..................................................................250 mm/200 mm
Width:....................................................................150 mm/150 mm
Height:.....................................................................220 mm/80 mm
Adjustable torque and speed control
The control unit allows the pushing force and speed of fibre delivery to be quickly and simply adjusted to provide optimum installation time and prevent damage to the cable
Present automatic stop
The control unit can be used to presetting distance counter to stop after a certain blowing distance, making it
possible to work alone.
User-friendly touch display
The Microflow Touch’s control unit has a user-friendly touch display, which can be used to make a number of
different adjustment
Equipped with a unique protection technology
The unique protection technology that stops the machine if the fibre cable meets resistance. Any obstacles are registered by a sensor and the motor stops.
The machine will also stop automatically if the motor exceeds the preset maximum torque level.
In both cases, the machine stops immediately so the fibre cable does not get damaged.
It is ready to be used for work as every part functions excellently well.
Asking Price: USD$10,500
If you are interested in this please kindly send me a message via mail
esales2 at protonmail dot com
Thanks for your time...
h7m1
This is still available for sale and it is ready to be used for work
h7m1
Price reduced to USD$10,350 for a quick sale.
