lauren
    Sat Dec 08, 2018 7:35 am
Up for sale is a CP-302 MIG Welder with Wire Feeder, Accessory Package. New display unit, used a few times only, still like new conditions.
The Miller CP-302 MIG Runner Package offers 100 percent duty cycle using industrial power sources while delivering time-tested performance in semiautomatic applications for a variety of industries. In addition to a powerful machine, the MIGRunner Package includes a wire feeder, Bernard Gun, an Industrial MIG kit, and factory installed running gear/cylinder rack.
Features:
Adustable weld stabilizer (high-low inductance) provides the flexibility to produce the optimal arc characteristics. Use the high stabilizer setting for stainless steel and low setting for mild steel and aluminum. • Solid-state weld contactor provides longevity to match the ultra-durable and reliable reputation of the CP Series.
115 VAC duplex receptacle provides 15 amps of auxilary power.
14-pin receptacle provides quick, direct connection to wire feeders and accessories.
Presettable welding voltage with voltmeter allows you to easily set weld output before welding.
Large analog volt and ampmeters for easy viewing.
Power efficient which gives exceptional value and return on your investment.
Simple control panel with just one control adjustment. • Lower panel cover protects output connections from harsh welding conditions.
Comes complete with:
CP-302 power source
22A wire feeder
Bernard Q-Gun
Industrial MIG 4/0 Kit: Smith regulator/flowmeter with 10 ft (3 m) gas hose, 10 ft (3 m) 4/0 feeder weld cable with lugs, and 15 ft (4.6 m) work cable with 600-amp C-clamp.
Factory installed running gear/cylinder rack, and Cylinder
Am looking to get $2000
Pictures upon request. Thanks for looking!
