echosixmike
    Wed Feb 13, 2013 8:03 am
I'm reducing my equipment at work, so my Syncro 250 and DEL-200 are for sale. Just not using the stuff enough.
Syncro 250 comes with WP-26 and I'll include the argon bottle (110CF) if you like. It's down around 500psi, there's enough to test the machine out but that's about it. Asking $1500
The DEL-200 is a Deutz diesel AED, 225 amps AC, 200 amps DC, 4500 watts 115/230v in genset mode, low hours, I will include a Sears HF unit if you want to use this as a field TIG setup, but I have never wired up the HF set, so that's on you. Includes 50ft leads. Asking $1250
I'm just north of the city, not far off I-94. I invite you to come test the stuff out, I have forklifts so I can load the stuff into your truck easily enough. I'll get some pictures up soonest. PM me here or Email target 1371 at aol dot com (no spaces) Thanks. S/F.....Ken M
Red: PowerMIG 300, Square Wave 175
Blue: DEL200, Syncro250, XMT300
Green: STH160
Black: Tweco 181i Fabricator
Oddball: Craftsman HF unit
Those are good deals.
We could sure use another SW250 at work, and I'll mention it, but shipping to the gulf coast may be an obstacle. No doubt you'll have a walk-in buyer in no time.
You said WP-26, so it has the built-in water cooler? Does it have either of the optional boards (sloper, pulser)?
Looking forward to the pictures.
Steve
echosixmike
WP-26 is aircooled 250 amp torch, no water cooler. It's got the foot pedal and the usual stuff you need to weld aluminum. I haven't used it for anything else, and sadly haven't used it that much. I have a flex head, valved WP-17 25ft I could include in a deal but that'd require a little negotiation. I had this photo on the phone, so people can look up the manuals at Miller. I'll get some more pictures of the DEL, may have to rearrange some stuff, it's a working shop so the TIG is stowed in the tool room, which has one light bulb, the DEL is tarped next to a 5 axle detach trailer and the usual silly shop drama.
S/F....Ken M
Green: STH160
I've been dealing with WP-20's so long, I got mixed up.
The lack of a water cooler is likely an obstacle for us even at that price, due to the need to build/buy a cart that would accommodate one, combined with crating/shipping charges. I'll still see what the guy holding the purse strings says, though.
echosixmike
Here's the DEL-200. I'm still working to dig the Syncro out from behind a ton of "stuff" to get better pictures. S/F....Ken M
Green: STH160
