    Thu Jan 24, 2013 10:13 pm
    Eddy, TX
I had some flange pins made by a friends machine shop and thought I would see if anyone else would be interested.
Pins are 1018 Cold Rolled 1-5/8" O.D. and will work on flange holes from 1/2" to 1-1/2" and 3" thick approx. 1/2"-13 SS threads that are replaceable.
I had a custom "knurled" end put on them for a completely custom look.
Price $75.00 ea + shipping.
Flange pin.JPG (80.99 KiB) Viewed 1119 times
Flange pin female.JPG (89 KiB) Viewed 1119 times
Flange pin bottom.JPG (86.37 KiB) Viewed 1119 times
Ahh.
Also known as "two-hole" pins for flange leveling and alignment.
$75 each? Or per pair? (Two are required to be usefull).
Steve S.
    Eddy, TX
Steve,
Yes two-hole alignment pins they are, should have put that in the original description.
Unfortunately they were quite expensive to make and I had a minimum run of 10 sets to get into his schedule so they are $75 ea or $150 for a pair. Thought I would see if there was interest. I can wiggle on price a little, not much. I just need to get rid of the remaining pairs.
What possessed you to spend that money on a custom run? Is there an unusual feature?
    Eddy, TX
Steve,
Well that is a question.....Honestly it was intended to give to the guys and me to use, then I had this hair brain idea to sell them. I wanted something different I guess. Maybe I will remove these.....
Don't remove them.
They may or may not sell here, but they'll sell, and here is as good a place to advert them as anywhere.
