AKmud
    Fri Jan 25, 2013 1:47 am
    Wasilla, Alaska
I run a MM252 with a 30A spoolgun and am constantly fighting with anything out of position. A video with some tips for vertical and overhead would be GREATLY appreciated!
soutthpaw
    Thu Sep 18, 2014 12:14 pm
    Sparks, NV
Are you asking for out of position welding of aluminum with the Spoolgun or general when using MIG out of position.
AKmud
    Wasilla, Alaska
Aluminum with a spoolgun...
Steel isn't a problem, but aluminum gobs up and blows holes something fierce. I usually give up and fire up my Dynasty. The spoolgun is so much faster though.
soutthpaw
    Sparks, NV
How thick? Wonder if it has anything to do with heat rising?
AKmud
    Wasilla, Alaska
I'm thinking it has more to do with spray transfer vs short circuit. Maybe I just need to dial things back a bit and get away from the spray.
Drifta-X
    Mon May 26, 2014 2:53 am
    Melbourne Australia
From what I have read, spray is for flat and possibly horizontal only, but that could be only for steel
I have a soldering iron!
    Sun Oct 27, 2013 10:57 pm
AKmud wrote:I'm thinking it has more to do with spray transfer vs short circuit. Maybe I just need to dial things back a bit and get away from the spray.
Aluminum mig has to be done with spray transfer.
Can't say I've ever tried to go vertical or overhead with the spool gun - I like my tig too much :D
soutthpaw
    Sparks, NV
Do you have pulse capability for your spool gun?
AKmud
    Wasilla, Alaska
No pulse on my 252 unfortunately...
