would be pretty cool, good arc shots using his PowerMig 350 mp with arc force and that kind of stuff,as I do a fair amount of this kind of work , John
jwmacawful
- jwmacawful
sure I'll try and download some pics , John
I do some big steel stuff , like mounting snow plows on trucks , and some work on farm machinery , and trailers , and quite a bit of general thick steel parts . I've hardly welded any aluminum still learning, don't have many aluminum projects coming around . I've yet to find some decent videos/arc shots on using large stick electrodes , I burn lots of 5/32 7024 and 3/16 8018 working on hitches, receiver, bumpers ,truck frames etc and I don't know if Jody will ever get any stuff like this / I think more stick welding would of been nice on that big square tube job that he used his PowerMig 350 MP even though I realize Mig was more economical and worked good on that job , sure stick welding has been neglected by many industries but its still a good process for heavy stuff and many kinds of stuff for me ,anyway. , as to pictures I have not got it set up yet , but I'm working on it thanks John
I don't have arc-shots, but I've burned a lot of 5/32 7018 on pipe, in all positions.
I always preferrred 1/8" though. I can do a 6010 root/hot and 7018 cap at one current setting.
Do use your dig funtion on your 105a 7018 fill and cap? Just wonderin.... Thanks John
I've not usually had "dig" available, including the pictured weld. I usually set it for 20% when I do.AKweldshop wrote:Do use your dig funtion on your 105a 7018 fill and cap? Just wonderin.... Thanks John
Steve S.
jwmacawful
- jwmacawful
jwmacawful
- jwmacawful
this was 2" i believe welded with 5/32 7018
- moment plate.jpg (36.38 KiB) Viewed 2632 times
jwmacawful
- jwmacawful
everyone and is dog must have done lots of these. partial penetration column splice using run-off tabs. these columns were 4" thick. preheat on these joints to remove surface condensation. welded with 5/32 7018. all welds were ut checked on this job
- column splice.jpg (34.42 KiB) Viewed 2632 times
do you just not believe in arc force? thanks for your time, JohnOtto Nobedder wrote:I've not usually had "dig" available, including the pictured weld. I usually set it for 20% when I do.AKweldshop wrote:Do use your dig funtion on your 105a 7018 fill and cap? Just wonderin.... Thanks John
Steve S.
The short answer is, I didn't have it, so learned to do without it.
"Dig" isn't about arc-force, anyway. It senses when you get too close and may "stick", and ups the current to prevent it. I also don't need a car that parallel-parks itself.
So if you had "dig" all the time , would you ever have a need/use for it? Thanks John
Yeah, I'll use dig when I have it. I'm not as steady as I once was, and a li'l defense against putting the "stick" in stick welding is welcome.
It's just another case of "I learned without it, so I can make do without it." Having it is an advantage, unless it becomes a crutch for poor technique.
Understood
Thanks
Thanks
