http://youtu.be/m2E_PAgoGSE
Well, no use beating around the bush. I am trying to sell a few tig fingers in this video.
let me know what you think about the split screen view. I finally figured how to do it and I think it will help in future videos.
=====admin wrote:http://youtu.be/m2E_PAgoGSE
The use of the split screen was a plus.
Perhaps the following comment might seem a bit extreme, but supplying additional data on the video screen(s) would be helpful. For example, an internal view of the weld would also be a thought, if there is borescope technology that could handle the heat. And, in a tiny box some where on the screen(s) the on-going actual amps/volts readings. If it is a joint where the interpass temperature is a requirement, another little box somewhere on the screen(s) indicating the on-going temperature that would correspond to a sensor positioned on the somewhere on the weldment.
Anyways ... that is what happens when you give a kid a piece of delicious milk chocolate ... they start fantasizing for gianduja.
Tanks for the video and the introduction of the various helpful technologies (insulated finger and telescoping led light).
Alexa
