Well thanks sir, It took me sometime to get it down to look like this its all about getting in a groove I myself had the same concerns as you did upon seeing this when I started the other company I got laid off from was agricultural stuff
Greg From K/W
- Greg From K/W
I said the same thing the other day at work while discussing this very topic.... A guy at work was Migging some bollards up and then was grinding them down extensively to make them smooth, I grabbed one and tig'd it quicker and it didn't need any clean up.Otto Nobedder wrote: I can TIG 1/8" rod just as fast as I can MIG .035 wire, get that even ripple, and not worry I've cheated strength for appearance.
Steve inspired me to try this MIG like TIG practice. I was not trying to get to aggressive, but wanted to keep this thread going. Specs; MM252, ER70S-6 .035, 18.4V 265 WFS. Enjoy.
- MIG like TIG.JPG (110.82 KiB) Viewed 1407 times
More heat there Johnathan!!!
Looks a little cold for my taste....
~John
~John
John,
I would agree with you if this were a weld to depend on. I will go out on a limb here and say while I do like the MIG like TIG look, I do not like it as common practice for my welding projects. I gave this weld a total of one minute and moved on. I much prefer the smooth and hot weld, as I feel this burns in deeper and is safer. Now this is not meant to offend or start a discussion on which is better, as I don't want to hijack this thread. Stay with the MIG like TIG theme and I will give it another go in the future.
Hey, no offense, just the critic in me.
I like a smooth, flat, washed in weld.... just me I guess.
~John
~John
Absolutely no offence taken!AKweldshop wrote:Hey, no offense, just the critic in me.
~John
If you want to have a real read, here the WW mig like tig thread
http://weldingweb.com/showthread.php?30845-Mig-like-Tig
Well I came home and gave it a quick shot again. Not much different but here it is. I would like to see some of you give this a try. Now that I have started, I won't be satisfied until I can get it to look like ZTfab's.
- MIG like TIG 2.JPG (123.36 KiB) Viewed 1632 times
Thought I heard somewhere that he uses a CNC stepper machine....
countryboy1127
- countryboy1127
Here's a few I done
- 20140401_084248.jpg (40.15 KiB) Viewed 1617 times
- 20140401_112732.jpg (48.58 KiB) Viewed 1617 times
- 20140401_112918.jpg (48.01 KiB) Viewed 1617 times
Nice! What were your specs?
countryboy1127
- countryboy1127
Again,
Looks too cold for my taste.
I'll get my powermig set-up and show you my mig welds.
IMVHO, and my $00.2
~John
IMVHO, and my $00.2
~John
countryboy1127
- countryboy1127
Wow, 18ga.
I'm sorry.
I thought it was closer to 1/4.
If that's the case, WOW!!!!
I'm sorry.
Lolz, The extreme close up makes it look like Half inch plate. The weld must be tiny. Still buff off the scale though.
countryboy1127
- countryboy1127
Sorry guys let me correct myself its 3/16 . I posted the wrong pictures . You are correct ak good eye even looking at a picture lol
That is where the dime next to the weld helps to show actual sizeweldin mike 27 wrote:Lolz, The extreme close up makes it look like Half inch plate. The weld must be tiny. Still buff off the scale though.
- Wiredwelder
Very nice guys ! @jdiggs how did you get the part so clean without spatter ....I see very little, very impressed with the cleanness!
Using a wire wheel is cheating...just so you know....Wiredwelder wrote:Very nice guys ! @jdiggs how did you get the part so clean without spatter ....I see very little, very impressed with the cleanness!
It's the only way tho...
Gotta paint the parts anyway....
