- Farmwelding
I made a stainless steel die (dice) but when I went to drill the holes in the mill some holes would just force the bit into the chuck and melt the bit. I used several speed settings and oil. Some holes drilled alright but some would not. Any suggestion would help.
Yep. Stainless likes very low RPMs with high pressure to make those ribbons peel off/up the bit. When you have the right pressure, you'll know by the ribbons peeling off silver. If they're straw-colored, your pressure is too high. If you get chips, your pressure is too low. If you can't get either, your bits are too cheap.
There is a cutting "wax" called Cut-Eeze, but I prefer Tap-Magic thread-cutting oil. The wax is far less expensive. I look forward to Josh's update on the cutting paste he mentioned.
- Farmwelding
I've been using some drill bits from enco, taping oil like Otto mentioned and 600-1400 rpm depending on the size of the drill bit ( starting small then increasing size)
- image.jpeg (36.66 KiB) Viewed 1024 times
- image.jpeg (34.95 KiB) Viewed 1024 times
When nothing else will do Plain Old Lard,even bacon drippings from breakfast pan.
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
135 ro 140 degree drill is good
four faceted drill points better
must be sharp and cool or it
will work harden the stainless
The_Fixer
- The_Fixer
I'm sneaky.... I give it to someone else to do.....
But 1500 RPM sounds very high On any size.
I often find a drill bit in the workshop kit with a melted end on it and we say "who has been drilling stainless?"
Usually find out it was that Chinese fella again. Sum C**t.
kiwi2wheels
- kiwi2wheels
That guy gets around ...............The_Fixer wrote:I'm sneaky.... I give it to someone else to do.....
Bill Beauregard
- Bill Beauregard
My neighbor, now deceased said you can't drill stainless without bees wax. I had a large volume because my grandfather was a shoemaker. I now will need to find more. His theory was the excess heat was consumed melting the wax. Bee keepers are all around, I hope it won't be hard.
Bees wax is indispensable for locks, windows, drawers, doors, planers, wood working machinery etc., etc.
