Corvetteed
- Corvetteed
I am rebuilding a 2014 Silverado the truck ran over a fire hydrant and punched a hole in the bottom of the rear . differental by the time I have ground out all the cracks the hole measures 2x3 inches I have bent a piece of bar stock to fit in the hole is there any way this can be welded. I have a Miller 200 mig machine can this be used?
If its clean it can be welded, Id be more worried about making sure no other stress cracks or issues are anywhere else that may have it twisted or tweaked. I typically TIG on rear ends but the MIG can work, ER70S6 filler should work fine...if necessary you could preheat it with a torch first, let it cool very slowly.....Corvetteed wrote:I am rebuilding a 2014 Silverado the truck ran over a fire hydrant and punched a hole in the bottom of the rear . differental by the time I have ground out all the cracks the hole measures 2x3 inches I have bent a piece of bar stock to fit in the hole is there any way this can be welded. I have a Miller 200 mig machine can this be used?
Make sure it is clean, which can be tough gear oil is a PIA.
