I'm just a novice, so I've got a novice question.........
I bought a "project" that has a few 1/8' mild steel T joint welds that are "cold" and "globy". If I grind away as much of the existing MIG weld as I can: 1. Can I TIG weld over the MIG weld? or, 2. Should I re-MIG weld over the MIG?
What I need to understand regarding either approach would be much appreciated!!!
dirtmidget33
- dirtmidget33
1.Depends how clean can you get it? Was it painted, rusted, powder coated, etc. Do you feel like cleaning real good. TIG likes it clean
2. What are you more comfortable with? MIG or TIG
3. Which process is gonna be the easiest to get into location?
4. Would splatter effect area around it?
Either one works great when done right. Just depends I TIG stuff most people would rather MIG, but I like TIG so that's what I use.
It comes down to what weld quality you need to have. What is a "project"?
Do you require structural integrity or is it just an appearance issue?
If you have a poor weld that need to take load, grind it down and re weld using the procews you do best.
Appearance, smooth it out with a grinder then wash the remains with tig.
what kind of media did you use in the
blasting process. some area better suited
where welding will take place.
make sure its not impregnated in any
of the remaining weld metal.
I just repaired some 14 year old aluminum ramps that were originally welded with mig.
I cleaned them up and tig welded them - no problems to speak of really.
I've had this problem before - a little cleaning with a die grinder and I was back in business.motox wrote:what kind of media did you use in the
Good reminder
