Stainless mig welding
Posted: Wed May 27, 2015 11:02 am
by prall34bears
I am in the middle of a large stainless steel project. Here are the parameters:
16 gauge 304
all fillet welds using pulse mode on a Fronius machine
Running fairly hot 22.8v using .035 308 wire
Here's the problem, I seem to going through a lot of tips.
Any suggestions??
Re: Stainless mig welding
Posted: Wed May 27, 2015 1:44 pm
by Mike
Welcome to the forum.
Posted: Wed May 27, 2015 6:46 pm
prall34bears wrote:I am in the middle of a large stainless steel project. Here are the parameters:
16 gauge 304
Any suggestions??
Welcome!
This may be as simple as a "stick-out" issue. Does your WPS specify a range of "stick-out"? If so, is your tip flush with your shield, proud of it, or recessed? All these things have an effect in judging stick-out.
Posted: Wed May 27, 2015 7:26 pm
The only job I ever used. 9mm solid wire ss was a complete shamozzle, constant bird nests and welded tips shut. And a arrogant supervisor who only off of help was "must be the operator "....
Posted: Fri May 29, 2015 5:23 pm
by prall34bears
Thanks for the welcome. The stick out suggestion was a big help. Also, information to anyone who may have the same issue, I adjusted the factory setting on the burnback, turned it down to almost no burnback and ran almost a 10 hour shift with 1 tip. Hope that helps anyone in the future!!
Steve
Posted: Fri May 29, 2015 6:19 pm
Good to know, things like spool tension and liner condition will also have an effect like burn back
Posted: Sat May 30, 2015 7:58 pm
Good catch on the burnback!
We've only one machine at work with adjustable burnback, but I've never had to adjust it, so I forgot that option was even available.
Thanks for the reminder, and I'm glad you got it to go well.
Posted: Thu Jun 04, 2015 3:28 pm
by Boomer63
For all who posted on the Thread: Great replies! I learned a lot! Thank you!
