MartinB
    Sun Jan 25, 2015 7:18 pm
    Michigan
Can anyone recommend welding gloves that are good in cold weather? I weld in my unheated barn and get cold fingers when the temperature is below freezing. My current gloves are cloth lined pigskin Razorback brand that I picked up at the local farm store. They're fairly nice for cheap gloves and will serve me well in warmer weather.
That's a tough one, MartinB,
All gloves will be a trade-off between insulation and dexterity.
Someone once posted good reviews here for the " 'Ove Glove", as seen on TV. They certainly have high insulation value, but I'm iffy on the dexterity.
Tillman makes a MIG-specific glove that has good mobility, but heavier insulation than a standard TIG glove.
When working outside in Iowa in winter, I kept heavy gloves inside my coveralls to keep them warm while wearing goatskin gloves to weld, then would swap them after each completion. For multiple welds, I would warm my hands on the recently welded pipe before beginning the next.
It was a "deal with it" situation.
I doubt any of this is helpful.
MartinB
    Michigan
Thanks Steve. I guess I was dealing with it the same way. I kept my warm (non-welding) gloves inside my jacket while welding, and switched them for the welding gloves when I could. Today I tried some thin jersey gloves inside the welding gloves but it was too tight of a fit. Lately, my welding has just been practice on the weekends. I'm saving any actual projects for warmer weather. Unfortunately it looks like that will be a while. The forecast high temperature this weekend is around zero degrees Fahrenheit. :(
    Tue Aug 19, 2014 2:34 am
    Short Creek, Arizona
If you're just practicing, get some heavy plate and crank up the amps. those welding gloves will be toasty soon enough :lol:
Cheers.
-Eldon
Miller Dynasty 280DX
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Victor Oxygen-acetylene torch
    Sun Sep 22, 2013 10:14 am
    Minneapolis Mn 55407
I like these, lined,snug fit
http://store.cyberweld.com/bsxwegltigwe.html
many choices and a section for cold weather
http://www.revcoindustries.com/catalog/ ... cts_id=670
VENTILATION and small torpedo/bullet heater for quick area warm or propane sunflower fish house style
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
