What is the best method to weld two steel 1/4" bolts together, end to end?
TIG? MIG?
Thank you for your help.
I have to ask why?
You can use a threaded rod, run two nuts to the middle, same visual effect.
But for your question, I have a tig, so that's what I would use.
clean the bolts remove galvo and weld mig, tig. the strength will no longer be what the bolt was. I assume you want to weld head to head. I second the idea of using threaded rod and 2 jam nuts or 2 regular nuts or a coupling nut with a hole drilled in it where you can then weld that in place
