Robajob23
    Wed Jan 11, 2012 10:43 am
firstly sorry for the spelling and grammer am crap at it. I was just wondering im after moveing to canada and away from the UK but dont know if my level 3 NVQ in Welding and fabrication will mean anything overseas any advice?
Ultralow787
    Fri Apr 29, 2011 11:30 pm
    Ontario, Canada
Where abouts in Canada do you want to come to, and what type of welding experience do you have?
Some Provinces require a C of Q (Certificate of Qualification) as a Welder, but in others it is a voluntary trade. I would suggest you obtain a leter from your previous employer(s) stating your work experience in the field you wish to pursue. If you can pass a CWB (Canadian Welding Bureau) practical test or TSSA (Technical Standards and Safety Authority) test for pressure vessels or pipe, you would most likely be welcome here!
Give me more details, and I'll get you whatever info you need!
Hobart 210 MVP MIG Welder
