Gas connection spanner size standards
Posted: Sat Nov 06, 2021 3:18 am
by Jack Ryan
There was a time when I only needed my "gas spanner" to fit and remove regulators and gas hoses.
Gas Spanner.jpg (84.48 KiB) Viewed 7238 times
Now the regulator nuts are different sizes - 28.6 mm, 28 mm, 25.4 mm (1") and others. That's a pile of spanners or a shifter that always needs shifting.
Just because one standard is good, it doesn't mean that several are better. No doubt there will be a gas multi-tool on Wish soon.
That's progress I suppose.
Jack
Re: Gas connection spanner size standards
Posted: Sat Nov 06, 2021 1:03 pm
by Gdarc21
I find a 1 1/8 spanner for reg to bottle and 3/4 spanner for lead gets me out of trouble but you can use a mobile lathe :lol: (shifter) for it.
Posted: Sat Nov 06, 2021 3:15 pm
by BugHunter
The nicest thing about standards is, everyone can have their own. ;)
Posted: Sat Nov 06, 2021 3:52 pm
by Gdarc21
Oh I forgot, I saw a multi tool spanner in gasweld yesterday. In the welding section. $ 9.95
I have too many shifter to bother but yeah it's out there. :D
Posted: Sat Nov 06, 2021 8:33 pm
by Jack Ryan
Gdarc21 wrote: Sat Nov 06, 2021 1:03 pm I find a 1 1/8 spanner for reg to bottle and 3/4 spanner for lead gets me out of trouble
So all your regulators require the same size spanner? I have CIG, BOC and several others and they don't.
In the context of spanners, I have no idea what that means.
Jack
Posted: Sat Nov 06, 2021 8:36 pm
by Jack Ryan
Gdarc21 wrote: Sat Nov 06, 2021 3:52 pm Oh I forgot, I saw a multi tool spanner in gasweld yesterday. In the welding section. $ 9.95
Sorry, I don't know what that means either. Multitools at Gasweld are not spanners.
Jack
Posted: Sat Nov 06, 2021 8:38 pm
by Jack Ryan
BugHunter wrote: Sat Nov 06, 2021 3:15 pm The nicest thing about standards is, everyone can have their own. ;)
Makes compliance easy. Whatever you do is bound to be a standard!
Jack
Posted: Sun Nov 07, 2021 10:59 am
Posted: Sun Nov 07, 2021 6:06 pm
by Gdarc21
Jack Ryan wrote: Sat Nov 06, 2021 8:36 pm
Jack
Yeah right. Oh well I will leave it up to you then. Have a good day :)
Posted: Sun Nov 07, 2021 7:19 pm
by Jack Ryan
Poland308 wrote: Sun Nov 07, 2021 10:59 am https://www.amazon.com/dp/B07NVHYKF1/re ... asin_0_img
Problem solved!
Yes Crescent wrench - aka Shifter, Shifting Spanner. Another standard .. :)
Jack
Posted: Wed Nov 10, 2021 3:31 pm
by Toggatug
I'll just add in my "universal" wrenchImage
Posted: Wed Nov 10, 2021 6:53 pm
by Jack Ryan
Toggatug wrote: Wed Nov 10, 2021 3:31 pm I'll just add in my "universal" wrench
I think you might have been around longer than I have :)
Posted: Wed Nov 10, 2021 8:47 pm
by Toggatug
Take a guess you'd probably be surprised.
To be honest though I don't have a clue how old that wrench really is. I just know it's been here since I got here.
I also know our shop can make a tool look like that within a couple years, lotta acid fumes floating around and allotta moisture
Posted: Wed Nov 10, 2021 9:32 pm
by Jack Ryan
Toggatug wrote: Wed Nov 10, 2021 8:47 pm lotta acid fumes floating around and allotta moisture
Sounds like the '60s
Posted: Thu Nov 11, 2021 6:51 am
by Toggatug
Oh god I'm glad I wasnt around in the 60's I've been told that in The 60's the smoke was so bad in the shop that it was a constant haze with some areas being so thick you could hardly see your hand in front of your face. You could argue that was also the hay day of the industry though
And of course back then it was lead/muriatic acid/flux fumes (not sure what they were using as flux but can bet it was more volatile then today's flux)
Posted: Thu Nov 11, 2021 7:49 am
by Jack Ryan
Toggatug wrote: Thu Nov 11, 2021 6:51 am And of course back then it was lead/muriatic acid/flux fumes
Ah, I thought it was lysergic acid diethylamide and tetrahydrocannabinol.
I'm not sure if I should be relieved or disappointed.
Jack
Posted: Thu Nov 11, 2021 11:23 am
by Toggatug
Ehhh wouldn't shock me of that was in some of the workers systems like alot of people of that era [emoji14]
The good ole days as the ole boys call em. "Nobody cared if you were messed up on this or that as long as the job got done right and quickly" can't tell you how many times I've heard that rant.
