Hi,
I a beginner, just finished my first argon bottle and when I replaced it, reconnected everything, I realized that the flow wasn't going any higher than 3 lpm.
After some debugging, I verified that the flow spikes once I shut the cylinder valve down, topping up the flowmeter until there isn't any pressure in the regulator.
The cylinder pressure is at 2650 psi.
I posted a video to better explain: bYmkU2kbixU
How do I fix this?
Thank you
Are you doing that with no hose attached to the flowmeter? Perhaps it is tripping a max flow limiter in the regulator.
If it still does that when connected to the welder, then I would say something is wrong with the regulator.
i suspect its the tank pressure shutting the regulator valve. quite possible it got a bit of dirt in it on the change over.
or its just a junk regulator which is not uncommon with cheap welders.
I would think the valve on the HP side is not seating or actuating properly. Many things could cause this. Take a wrench and lightly tap several times around the sides of the body of the HP side in the middle of the reg. It's a shot in the dark, but that can sometimes help to re-seat a catawampus component. If that fails, plan to buy a new reg. A higher quality one. I've found that trying to otherwise disassemble and "fix" faulty regs is a waste of both time and money.
Hi,
Following your suggestions, I de-attached the flowmeter and found gunk similar to dry honey in there. Cleaned it up, and now it flows perfectly.
Thank you very much.
- Gunk in the whole
- IMG_4868.JPG (43.5 KiB) Viewed 861 times
- It works
- IMG_4872.JPG (47.34 KiB) Viewed 861 times
