TigTag
    Fri Jan 29, 2021 9:14 pm
    CA & AZ
Hello everyone,
I'm in the process of making plans for a roof rack (for my van) and saw this video but the maker is not saying what material he is using (nor is there a contact) - I think it's 1.5 inch but would like a 2nd opinion.
Also, it looks surprisingly light as 2 people can handle it without a problem, do you think it would still be the case if it was made from steel?
I was going for 1.25 diameter initially. I think I will buy a piece of long stock in both 1.25 and 1.5 inch and put them up on the van temporarily to see which looks better (aesthetically proportional to the van size)
Here is the video (ignore the welding, it's his first time) https://www.youtube.com/watch?v=Nh4x3Y9MQT8&t=106s
Thank you
Screenshot 2021-02-04 153207.jpg (51.1 KiB) Viewed 2147 times
Screenshot 2021-02-04 153348.jpg (41 KiB) Viewed 2147 times
I’d guess 1.5”x0.125 wall thickness
TigTag
    CA & AZ
cj737 wrote:I’d guess 1.5”x0.125 wall thickness
I was thinking the same; many thanks once again!
Ballistic308
    Fri Jul 12, 2019 10:56 pm
.095” thickness is also completely adequate for roof racks and it saves ~25% in weight compared to .125”.
    Mon Feb 26, 2018 1:52 am
    Idaho
That is aluminum. You can kinda tell due to its dull finish.When he is cutting it with a hole saw it throws teary chunks, and when he cuts it with the cutoff wheel there are no sparks.
Ballistic308
bap_ wrote:That is aluminum. You can kinda tell due to its dull finish.When he is cutting it with a hole saw it throws teary chunks, and when he cuts it with the cutoff wheel there are no sparks.
And they’re using a spool gun which is a no brainer for mig welding aluminum.
    Idaho
Hah ya that'll do it. I didn't even notice, I skipped to the middle/end right off the bat.
    Mon May 21, 2018 9:47 pm
    Phoenix, AZ
Also the title of the YouTube video says aluminum
Sent from my iPhone using Tapatalk Pro
HTP Invertig 221H w/ Arctic Chill cooler and CK20 torch
Lincoln MP210 -- SOLD
Optrel Crystal 2.0
    Idaho
I submit hah :mrgreen:
1.25 or less. Even with long fingers they wouldn’t wrap around that far on 1.5. Old pipe fitter trick. Try it.
