- Radishfever
W
Learning is the best part of life and the most painful
You made some excellent, albeit a little brittle, foam-carbon heat insulation pads there!
If you put a blowtorch on one side you can usually still touch the back without getting burned at all. Quite interesting stuff, really..
Bye, Arno.
![Geek :geek:](./images/smilies/icon_e_geek.gif)
Bye, Arno.
EVERYBODY gonna be burning toast tonight!! LOLArno wrote:You made some excellent, albeit a little brittle, foam-carbon heat insulation pads there!![]()
If you put a blowtorch on one side you can usually still touch the back without getting burned at all. Quite interesting stuff, really..![]()
Bye, Arno.
- Radishfever
Arno
- Radishfever
