39 chevy front sway bar
Posted: Sat Feb 04, 2017 1:55 pm
by motox
a friend has a 39 chevy master deluxe street rod.
he wants to adapt a larger diameter front sway bar from
a newer model chevy but it would require cutting
and welding.
any help here on the do or do nots of a project
like this?
Re: 39 chevy front sway bar
Posted: Sat Feb 04, 2017 2:09 pm
by mpete53
from what I understand sway bars are actually a type of torsion bar spring. The bar twists as one wheel tries to move differently than the other. I would think they are a heat treated high carbon steel that would not work will after welding
Mark
Posted: Sat Feb 04, 2017 2:31 pm
by exnailpounder
motox wrote:a friend has a 39 chevy master deluxe street rod.
and welding.
like this?
Craig, you are probably more than capable of doing this project but this is a critical part so if something ever happens, it's your ass on the line. My humble opinion.
Posted: Sun Feb 05, 2017 9:09 am
by motox
mark
not being a car guy i have a limited idea of
the material used in sway bar on a car built before i was born
operates. my first thought was heat treated but
figured one of the genius car guys had more info.
thanks for your reply.
Posted: Sun Feb 05, 2017 5:12 pm
by ryanjames170
motox wrote:mark
so i can answer on the steel from what i know about swords.. they are spring steel as well, why back yard sword makers love old springs
so your average welding filler metal lacks any kind of spring like properties ie it bends much it stayes hence why when you bend test something it stays bent and dose not "spring" back and evan if you heat treated it it would still lack all spring steel qualities in the weld aria.. so if it bent it would stay bent..
bottom line dont evan bother with it.. there are places they make springs and i bet they would be able to make what he needs.. one of those places over in MN is husky Spring
Posted: Sun Feb 05, 2017 6:32 pm
by Rudy Ray
Yes, as the above mentioned. Sway bars are spring steel and for your intent, not weldable.
Posted: Mon Feb 06, 2017 8:30 am
by motox
thanks guys. its great to have such a large group
of knowledgable, smart minds to pick!
he found an after market company that makes
the components to upgrade.
Posted: Thu Feb 09, 2017 12:28 am
by Bill w
This actually isn't a hard job. There are gm sway bar mounts you can buy from energy suspension. Then you just need to find a sway bar from another car that meets your needs. The welding from this point would be on the parts that you would be attaching this to.
Posted: Thu Feb 09, 2017 9:34 am
by motox
Bill w
"This actually isn't a hard job. There are gm sway bar mounts you can buy from energy suspension. Then you just need to find a sway bar from another car that meets your needs. The welding from this point would be on the parts that you would be attaching this to."
Bill
thank you i will happily pass this on to my buddy.
