Welder & Generator compatibility
Posted: Mon Sep 19, 2016 12:45 pm
I'm new to welding, I haven't ever done it before but I need to start learning. I've learned most of the facets to get started, and now I'm looking at an equipment compatibility before I can even plug it in. Also I have some 6011 & 6013 1/16" sticks, for the 2nd part of my question.
The Welder: Lincoln Electric Inverter Arc 230 (Century K2790-1) (30A max, 230V, 6-50P)
The Generator: Generac GP5500 (L14-30R)
First issue is that I don't have a 6-50R receptacle anywhere near where I want to be welding. I considered getting an extension and using my range stove, but for a 50ft cord it would have to be fairly thick and expensive.. So I have a generator I can wheel around instead. It hasn't ever been used, and its only purpose was to feed the house if we have another long term power failure. I was going to purchase the Lincoln AC225 but at 50A they said their efficiency required a generator capable of 15KVA. Stuck on wanting a quality stick welder, I went ahead and purchased the 30% duty, 30A model.
The plan is to take a L14-30P and a 6-50R and make a foot-long adapter to be able to connect the welder's 6-50P to the generator's L14-30R, with some 8/2 or 10/2 cable. My concern is this "efficiency" thing and whether my generator will be capable of powering this welder. Maybe I got a little ahead of myself, but I liked the idea of using this pair for all kinds of things.
2nd part: So I have these 1/16" sticks, and this welder says it recommends 5/64" to 5/32" sticks. Can I simply turn the amps down to 35-45amps or so, and use these 1/16" sticks even though they're too small to be recommended? Originally I was rewiring power transformers and bought some things before I thought I should just go ahead and buy a quality welder, and only planned to use these thin sticks for fabricating some basic foundry tools.
Answers? Advice?
Thank you in advance!
Answers? Advice?
