motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
with all the trailer builds here though this might
helpful to someone.
qu29891_2_800 trailer.jpg (60.58 KiB) Viewed 1785 times
ShaunBlake
    Fri Jan 02, 2015 12:03 pm
    Sugar Hill, Georgia (U.S.A.)
Thanks! (Don't expect to ever need it, but I keep thinking of dumping my utility trailer and building my own.)
I learned CG calculations while studying aircraft design, and this information is spot on.
I hope many would-be trailer builders pay attention to this.
It's also useful if you buy a home-built trailer. Step one is to verify CG, and step two is to check tracking against the hitch.
ShaunBlake
Otto Nobedder wrote:... and step two is to check tracking against the hitch.
Hunh? How would you do that? Tow it in a straight line then stop and measure from the center of the hitch to the outermost point on the axle you can reach; each side must be nearly exactly the same dimension?
Or do you mean some other tracking?
Boomer63
    Fri Sep 12, 2014 11:52 am
    Indiana near Chicago
The way I have done it is to find center of hitch; mark it and drop a plum line. Measure from a set point on the axle on both sides. I did use the 'U' bolts. That is how I was able to center out the hitch. Maybe not the most efficient method, but it worked just fine for me.
Gary
ShaunBlake
Boomer63 wrote:...
Gary
Ah, got it. It seemed to be what Steve (Oo No) was recommending, but I haven't seen it referred to as tracking, and wondered if there might be some other meaning.
On a side note, what is the consequence of having the axle twisted out of square to the travel? It doesn't seem that the tire wear would be excessive unless the angle was so great that the trailer trailed with a considerable shift to the side. And it seems that if it trailed an inch or two to either side, it wouldn't he hazardous, even loaded. Wouldn't it have to trail half a foot or more to the side to cause problems braking?
PS: Are you sure that SteveS didn't mean tracking me with spy satellites? :shock:
Boomer63
I have a theory that all trailers are slightly 'out of alinement' ... but no one seems to care because there doesn't seem to be any consequences. On the other hand, I might be completely wrong and full of shit. My rule of thumb on projects like this is that if it seems to be tracking straight, it probably is. If the tires aren't wearing, they aren't. If it looks straight, it probably is. Or something like that.
I work with trailers that weigh 26 tons empty.
I align the axles to the fifth-wheel hitch with a tolerance of 1/16 of an inch.
Tire wear is one concern. Fuel efficiency is another.
If your tractor (or truck) has to side-pull your trailer, even a little, it costs you both fuel and tire wear.
ShaunBlake
Otto Nobedder wrote:I work with trailers that weigh 26 tons empty.
So you prolly know what I've puzzled over: in a previous lifetime, I worked at a large scrap metal company. The welders would occasionally need to build "new" trailers, and one of them mentioned to me that the hind-most of the tandem axles had to be offset 6" from the leading axle or it wouldn't track properly. Can you explain the dynamics? It seems counter-intuitive to me.
ShaunBlake wrote: ...one of them mentioned to me that the hind-most of the tandem axles had to be offset 6" from the leading axle or it wouldn't track properly. Can you explain the dynamics? It seems counter-intuitive to me.
The dynamic here is that the man in question was a complete idiot.
When I install a new air-ride, each pair of suspension towers is equidistant from the pull-point (king pin of the hitch) within 1/16" inch, and both front and rear towers are square within 1/16" before the first tack weld happens. This is done on a level surface with plumb-bobs. Additionally, the distance between front and rear tower sets is 49" within 1/32".
The result is, when I do the wheel alignment, the aligning cams are never moved more than 5* from the 12:00 position.
It really doesn't add much labor time to do it right, and saves the clients a fortune in tire wear, fuel, and general maintenance. Our primary client is impressed enough with my method and it's results that we now measure suspensions installed elsewhere, and will cut them out and replace if they're not within tolerance.
ShaunBlake
ShaunBlake wrote: ... tandem axles had to be offset...
Well, he wasn't alone, and I don't like having such thoughts about them. However, it has really bothered me all these years because it was so contrary to my scant knowledge of physics. I am very grateful for your clarification!
Boomer63
Steve, you are working with trailers that are way, way bigger than I have built. I have put together some custom jobs for hauling skid-steers, etc. Nothing like the big boys you are talking about.
    Sun Sep 22, 2013 10:14 am
    Minneapolis Mn 55407
Every thing Steve says about alignment applies, big or small. Simple tools ,plumb bobs and string works as well as lasers etc.
Practical application of what is at hand is all that is needed. KISS.
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
nathan
    Sun Jun 16, 2013 1:20 pm
    Texas
I need to remember this post. I want a truck just so I have an excuse to build a trailer. This will help :)
Instagram: @nathanppiatt
Lincoln Weld-Pak 125 HD
Lincoln AC/DC 225/125
Lincoln Port-a-torch
Bill Beauregard
    Thu Jan 24, 2013 9:32 pm
    Green Mountains of Vermont
I have a feeling if you took a Dale Carnegie course you failed. I got a good laugh at that.
Bill Beauregard wrote: I have a feeling if you took a Dale Carnegie course you failed. I got a good laugh at that.
I've read his book, "How to win friends and influence people".
Excellent read. I use it often, but selectively. Sometimes, you have more influence by being very direct, and skipping the dance around the facts.
The one I read was "How to lose friends and alienate people" ;-)
Miller Bobcat 225
Tweco Fabricator 211i
AHP AlphaTIG 200x
Lincoln SP-135+
Hypertherm Powermax 30 Air
ProStar O/A torch
