ATubbin7
    Sun Jun 21, 2015 6:55 pm
    Missouri
Hello,
So I have the Lincoln 3350 welding hood and last week the shutter started to basically static between dark and not dark and then just stopped working. I am having it sent in to Lincoln because it is still under warranty, but my question is, why would it just start acting up out of no where and stop working? I changed the battery and the problem continued.
Thank you for the help.
- Austin
    Tue Jun 26, 2012 8:05 pm
Cold solder joint. https://learn.adafruit.com/adafruit-gui ... n-problems
ATubbin7 wrote:Hello,So I have the Lincoln 3350 welding hood and last week the shutter started to basically static between dark and not dark and then just stopped working. I am having it sent in to Lincoln because it is still under warranty, but my question is, why would it just start acting up out of no where and stop working? I changed the battery and the problem continued. Thank you for the help. - Austin
ATubbin7
    Missouri
Thanks!
