brownbess
    Thu Jun 30, 2011 10:58 pm
    Central Florida
Man, I have this great machine, bu a very small circuit to use it on, what I need to know is what the minimum breaker I can use to run the machine at 135 amps?? I will shoot a memo to Miller, but getting a 100 amp breaker into the house is a problem...Thanks for the advice, BrownBess in 'sunny' Florida. 8-)
Synchrowave 250,Dynasty 200 DX,Millermatic 250MP,Hypertherm Max43,Bobcat 225NT,Ellis Band Saw,Bridgeport Mill,Clausing 14" Lathe,16" Black & Decker Radial Armsaw,Hammers
delraydella
    Mon Apr 25, 2011 7:35 pm
    Detroit, MI
You could probably get by with a 60 amp breaker on a 220 line. Anything less would be pushing it.
Steve in sunny (and hot) Michigan
