I'm spot welding stainless sheets with Entron EN1000 and TW110 handpiece. Have done alot of it. Now my handpiece is getting hot as well as the leads and its burning through the metal. All my settings are the same, it just started happening. I am not an experienced welder, if it weren't New Years eve, i would call somebody to help.
jwright650
- jwright650
Keep an eye on your cables/leads....particularly the connections. Make sure nothing is loose, as this causes resistance to the current flowing, resistance causes additional heat.
John Wright
Thanks, I have looked at any obvious problems; grounding, leads, possible damage to the handpiece.jwright650 wrote:Keep an eye on your cables/leads....particularly the connections. Make sure nothing is loose, as this causes resistance to the current flowing, resistance causes additional heat.
jwright650
- jwright650
page 117 has a couple troubleshooting tips for "Hot" weldsWerkSpace wrote:Do you have the instruction manual?
http://www.tjsnow.com/manuals/entron/1001cascade.pdf
If the machine settings are all the same, maybe the air pressure has dropped for some reason.
John Wright
