Alright guys today is the day. My Everlast let me down. Everlast Super Ultra 205 tig stick plasma. I finally wired in 220 to our building and hooked it up. It worked perfect all day. I fired it up and went to cut with plasma and it arced one time and died. No power at the terminals. The machine has power, the fan runs it adjust everything works except the weld leads. What may have happened?
Matt
Matt
mcoe wrote:Alright guys today is the day. My Everlast let me down. Everlast Super Ultra 205 tig stick plasma. I finally wired in 220 to our building and hooked it up. It worked perfect all day. I fired it up and went to cut with plasma and it arced one time and died. No power at the terminals. The machine has power, the fan runs it adjust everything works except the weld leads. What may have happened?
That Sucks Matt!!!
Did you call or email Everlast??
Mark
performance@everlastwelders.com
http://www.everlastgenerators.com
http://www.everlastwelders.com
877-755-9353 x204
M-F 9am - 5pm EST
Negativ3
- Negativ3
Possibly the torch switch wire has become disconnected inside the torch?mcoe wrote:Alright guys today is the day. My Everlast let me down. Everlast Super Ultra 205 tig stick plasma. I finally wired in 220 to our building and hooked it up. It worked perfect all day. I fired it up and went to cut with plasma and it arced one time and died. No power at the terminals. The machine has power, the fan runs it adjust everything works except the weld leads. What may have happened?
Roast beef and Yorkshire pudding is my personal signature dish.
Stupid questions are better than stupid mistakes.
I tore the switch apart looking for a loose connection. I hooked the tig torch up and had no fire. I hooked the stinger up and tapped the electrode on the ground clamp and it wouldn't spark. I have no power at all at the leads.Negativ3 wrote:Possibly the torch switch wire has become disconnected inside the torch?mcoe wrote:Alright guys today is the day. My Everlast let me down. Everlast Super Ultra 205 tig stick plasma. I finally wired in 220 to our building and hooked it up. It worked perfect all day. I fired it up and went to cut with plasma and it arced one time and died. No power at the terminals. The machine has power, the fan runs it adjust everything works except the weld leads. What may have happened?
John, it happened last night so I am waiting till tomorrow to call since they are closed on the weekends.
Matt
Matt
delraydella
- delraydella
Check the power supply to the welder itself. You may have lost one of the legs on your 220.
I know it is killing me. Our business is depending on this machine. We have more orders than we know what to do with. We still have Hobart mig and Lincoln stick but not our tig stick plasma machine. All of our orders either need tig welded or plasma cut. We can still do our horseshoe art but not our major seller, plasma art. We were looking at buying a separate tig and separate plasma machine and I think we cursed ourselves by looking.
Matt
Matt
Best of luck to you Matt.
We'll see how good that 5 yr warranty is....
Here is the thing. I just hooked it up to 110 again and it works perfectly. I just wired it in to 220 yesterday and it worked fine until it pooped itself. I hook it to 220 and it turns on but doesn't arc but 110 it works fine. Here is the mystery. The old Lincoln won't even turn on now wired on the same circuit. Any ideas now.
Matt
Matt
Did you check for 240 volts coming out of the wall plug?
When you wired the 240v circuit, did you use two 120v breakers, or a single lever 240v breaker?
I only ask because if you used two separate breakers one could be not working or tripped.
Here is the update. We ran a brand new wire from the meter box to the building breaker box put a new breaker in and new receptacle and still no 220.
Matt
Matt
coldman
- coldman
So you have run a new wire to the 220 breaker. Have you also made neutral and earth connections?
If the answer is yes and you did the work yourself (not an electrician) then most likely one of the connections is faulty. Inspect each one and make sure the tightening screw is on bare wire not wire insulation. This happens alot.
I chased every single wire 5 times and every one is tight and hooked up right. We can only guess that there is something inside the machine that is messed up.
Matt
Matt
Wow, not sure if I want a machine that requires me chasing the wiresmcoe wrote:I chased every single wire 5 times and every one is tight and hooked up right. We can only guess that there is something inside the machine that is messed up.
Artie F. Emm
- Artie F. Emm
Some more clues, please: you said 'the machine worked on 220' until you used the plasma. The TIG welder worked on 220 until you tried the plasma, then both the plasma and the welder were down, then the welder worked on 110. Is that correct?
Can you TIG on 110 to get some of those orders out?
Dave
aka "RTFM"
aka "RTFM"
- Braehill
Matt,
You need to see if there is power coming from the meter socket and work your way through until you find where the power stops. You could have lost one leg from the transformer, it's rare but it happens. If you can verify power up to the welder itself, then you know it's the welder. You can buy a cheap multimeter at any hardware or even a Sears or HF.
Jonathan, that power cord runs away so you have to chase it. Everyone else, I hooked up the 220 and only ran the plasma. It worked fine all day, I shut it down went to town for about an hour came back hit the torch switch and the pilot arc popped one time and that was it. The air solenoid still works, the fan runs, the display works just no power at the leads. I have a multi meter and checked every connection and receptacle. I know I am getting 220 because my lincoln will start and weld just fine so I say it is in the machine.
Matt
Matt
My hobart works but it is a 110 machine. My Lincoln works but it has a different plug end so I can't hook it to my outlet in my building and I cant hook my machine in the outlet in the other building for the same reason.coldman wrote:I think it unlikely that both the hobart and green became faulty together. Maybe you have a faulty breaker or local isolator. Do you have a multimeter that you can trace voltage to where it stops?
Matt
Matt
mcoe wrote:My hobart works but it is a 110 machine. My Lincoln works but it has a different plug end so I can't hook it to my outlet in my building and I cant hook my machine in the outlet in the other building for the same reason.coldman wrote:I think it unlikely that both the hobart and green became faulty together. Maybe you have a faulty breaker or local isolator. Do you have a multimeter that you can trace voltage to where it stops?
You have a Ez-Tig right??
