I am interested in having for myself what gases are used most commonly for MIG and TIG processes. Also, what gases are more effective and with greater penetration and creating less spatter. I know it could be a lengthy explanation, but I would really appreciate your help. I weld on a variety of metals and always get confused which gases are for what metals. I have experimented a lot, but could use help. I have welded on metals such as: black iron, cold roll, hot roll, stainless (different grades), aluminum, copper, brass, galvanized, copper-nickel. A simple chart would be just fine. if you could please help me, I would greatly appreciate it very much.
Thanks,
Dennis
Welcome to the site Dennis!
If you follow this link it will take you to the information you are looking for. http://www.airgas.com/content/details.a ... 0000000143
I am going to move this over to the General Shop Talk forum where you will get more people to view your question.
![Image](http://i619.photobucket.com/albums/tt275/Fat_Bob/Off%20The%20Wall%20Stuff/RIDE.gif)
Most gasses are NOT inert.JDIGGS82 wrote:my question is probably a mdumb one but why do some gasses seem to run hotter if the gasses are inert what causes it to burn hotter?
Helium is inert.
Argon is inert.
You'll never afford the next inert gasses (Neon, Xenon, Krypton).
Everything else is an active gas.
I didn't really explain anything, though...JDIGGS82 wrote:well hell that explains it! thanks for taking me to school muych appreciated
That's because I don't really understand what goes on. 75/25 is 75% inert, and the 25% CO2 breaks down in some magic proportion where the free oxygen make heat and free carbon maintains the hardness of the steel.... This part of the process may as well be Alchemy (appropriate, since I want to see gold...).
Artie F. Emm
- Artie F. Emm
This document from Lincoln explains the various gases used for MIG (starts on page 12).
http://www.lincolnelectric.com/assets/g ... /c4200.pdf
Dave
aka "RTFM"
aka "RTFM"
- Braehill
@Steve,
This brocure that Artie references here has one of the easiest to understand explanations of the disassociation and recombination of active gases that I've seen. The whole thing is very much worth reading if you're into Mig welding, which I have to admit I don't know much about.
Thanks for the recommend!Braehill wrote:@Steve,
I'll take a minute to read this one.
Had a read, and learned a lot!Artie F. Emm wrote:This document from Lincoln explains the various gases used for MIG (starts on page 12).
Another example of the things that make this forum great.
Thanks for sharing!
I like this one for MIG gases, it lists transition points - I find that sort of stuff interesting
http://files.aws.org/wj/2006/02/wj20060 ... 602-46.pdf
