noddybrian wrote:@ TraditionalToolworks - I have little clue about modern tech stuff & no interest but my take on this is if the fault you experience is as you believe a problem with the forum pages then it would affect every member which it clearly does'nt & likely if every member was mentioning it then the PTB would do something to correct it
Brian,
Other people have confirmed in this thread that they see the same error when posting that I eluded to. I do have some clue about computer software as I have been writing it for over 30 years. While I don't currently work on web sites, I have worked on several for large companies. I have setup and run forums for large organizations and have even setup forums running PHP BBS on my own servers, although I don't have one running at this time. I did upgrade and reconfigure the forums that are used for the USA Table Tennis as well, although I did that on a volunteer basis.
Trust me when I tell you the error that is displayed to at least several people is not a fluke that I mention to confuse the admins here, it is something that I believe can be fixed fairly easy. It is something that has been an annoyance to several people, not just me.
Look, I only tried to help them by providing the error as it occurs. The error happens on the server side, not the client, so the device or software being used doesn't have too much to do with it. However to give some credit to what you suggest, YES, something browsers act differently on different platforms. I don't think that pertains here, but I could be wrong.
noddybrian wrote:I also use Firefox but not on Linux
Trust me when I tell you that this is basic functionality of the browser and really has nothing to do with the platform it runs on.
I seriously doubt that others seeing this problem are running Linux, most likely they are running Windows just like you because Windows is the most widely used client.
That said, there's an option at the bottom of the forum page which I just clicked on to "Reset Settings" as well as "Delete all board cookies", maybe that will have something to do with the problem. However, I'm not the only one seeing this issue, read back through this thread to see that both tweake and Richard have said they see this problem. My gut tells me they are most likely using Windows, one of the worst operating systems on the planet. If you go back up and read, Richard is using the Chrome browser.
EDIT: No, Resting Setting and Delete all board cookies didn't fix the problem, I just got logged out when submitting my reply.
No worries I know how to work around it, but if it was me running the forums I would have fixed the problem long ago.
EDIT2: that time worked, it might have something to do with Preview, I didn't Preview that time. Nope, I Previewed that time but it didn't toss that error. It's an intermittent problem.
