Anyways the issue I've got now is the gromet that seals around the fuel suction line cracked and started leaking gas. I got a new one that fits both the hole and the line, but the tank wall is almost 3/16" thick plastic and the gromet wouldn't seat properly and it leaked. I also notice that its now turned into like a hard plastic instead of a flexible rubber, is it possible the rubber gromet needs to be rated for gas or oil? Or isn't that the reason it turned so hard.
Miller doesn't have a part number for it, I can only order the whole fuel line, I don't know if I want to order a $100 part and hope that a $2 gromet comes with it...
Any help much appreciated!
![Image](https://uploads.tapatalk-cdn.com/20210209/19b1855ef83694b9edba842d69d938be.jpg)
![Image](https://uploads.tapatalk-cdn.com/20210209/2bd247976f33b9e41718db3ef60901a2.jpg)
