    Thu Feb 23, 2017 12:35 am
I am looking at buying a low end for our shop. All units I am looking at have a speed range of 2-10 or 20 rpm.
Do you guys think that the 2 rpm at the low end with still be too fast?
it depends on the diameter of what your welding, the larger the diameter the slower you need to go, also if the motor doesn't have enough torque the speed won't be consistent.
What is your budget for this?
LtBadd wrote:it depends on the diameter of what your welding, the larger the diameter the slower you need to go, also if the motor doesn't have enough torque the speed won't be consistent.
I have just been looking at the $3-400 CDN units. Not req'd often but handy to have. Small stuff only.
