Books, articles, websites and other sources of information.
The Extractor
    Wed Oct 16, 2013 10:58 am
Hi all, new here, a customer is having us extend a masonry bit. It is a 3/4 shank for an SDS hammer drill. I drilled a piece of solid 1" 1018 and shrunk fit it and welded it with UTP rod with a little preheat and put it sand to cool.
What is the " proper way " to do this?
Thanks - A
Mike
    Mon Dec 06, 2010 1:09 pm
    Andover, Ohio
Welcome to the forum.
I use extensions for drill bits.
M J Mauer Andover, Ohio
Linoln A/C 225
Everlast PA 200
jwmacawful
    Fri Aug 13, 2010 1:23 pm
    the city that never sleeps
for extending drill bits i use a length of round stock approxamatly the same diameter as the drill shank then use a cut off wheel to slice the shank between the drill flutes and the adaptor contours that go into the hammer-drill then lay all in the "v" of a angle iron held in a vice then clamp with a c clamp vise grip and tack with 7018. remove and check for trueness then weld and wrap in old welding gloves when finished so it cools slowly.
