Hi all, new here, a customer is having us extend a masonry bit. It is a 3/4 shank for an SDS hammer drill. I drilled a piece of solid 1" 1018 and shrunk fit it and welded it with UTP rod with a little preheat and put it sand to cool.
What is the " proper way " to do this?
Thanks - A
Books, articles, websites and other sources of information.
jwmacawful
- jwmacawful
for extending drill bits i use a length of round stock approxamatly the same diameter as the drill shank then use a cut off wheel to slice the shank between the drill flutes and the adaptor contours that go into the hammer-drill then lay all in the "v" of a angle iron held in a vice then clamp with a c clamp vise grip and tack with 7018. remove and check for trueness then weld and wrap in old welding gloves when finished so it cools slowly.
Return to “The Welding Library”
