Discussion about tradeschools, techschools, universities and other programs.
sedanman
- sedanman
I was really looking forward to it too. I had one week of formal training way back in 1986 and none since. I've been a hobbyist mig welder since and am now trying to learn tig and stick. I can't find any other adult ed program in my area. The registrar said they'd try again in the fall, l don't want to wait 6 months. I'm in Dutchess County NY if anyone wants a student.
Artie F. Emm
- Artie F. Emm
That's disappointing. Your post says it's "adult ed", maybe that's why. Is there a community college course, maybe?
Dave
aka "RTFM"
aka "RTFM"
The sad reality here is that there is no marketing for such a course. The school will put it in their syllabus, but never once publish a poster or take advantage of the local NPR station. If you're not looking, you won't know it exists.
sedanman
- sedanman
If you don't know exactly what you want and how to use it, most local welding supply stores will give you a cold shoulder and short answers. So you seek training and can't find any at the hobbyist level. I'm too old to go work as a journeman's helper sweeping the shop floor for minumun wage and the occasional welding lesson.
Artie F. Emm
- Artie F. Emm
Here's an outside-the-box idea: call the Boy Scouts.
No, really. You might call a local merit badge counselor near you and tell him you're looking for feedback / advice / troubleshooting. He may be a pro, or may be a hobbyist, but likely will have some spin on the ball. Offer to provide adult beverages and see what he says.
Dave
aka "RTFM"
aka "RTFM"
- RocketSurgeon
The AWS website lists lots of classes and schools, everywhere. Even if the local school doesn't have the schedule you need, you might be able to talk to the instructor about after hours or side lessons.
You might be able to contact a local high school that has a shop class that teaches welding and talk to the instructor about you dilemma.
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
sedanman
- sedanman
I got a call from BOCES last week. They have had additioanl inquiries and have rescheduled the class to begin May 16th. I am very happy and looking forward to class. Then I want tig training.
Now welding but, I wanted to take an automobile diesel class which had nowhere near enough students to continue. I asked the instructor if I could take a different class "title" and do the class I actually wanted. Turned out there was one class which meeded one more student to continue. The instructor agreed instantly, good for everyone.
-c-
-c-
Look! a hole in the space-time continuum!
- RocketSurgeon
That's awesome! Sounds like you have good game plan as well.sedanman wrote:I got a call from BOCES last week. They have had additioanl inquiries and have rescheduled the class to begin May 16th. I am very happy and looking forward to class. Then I want tig training.
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
sedanman
- sedanman
First class was Monday. Instructor is a good welder but not a good teacher. Brief safety talk, some oxy-acetalene instruction, we cut some coupons and after a very short arc strike demo we were set loose in a booth. I was hoping for a little direct observation and correction. Tonite, I'm going to drag a little more info out the instructor. I'll also post a picture of my pad of beads. The first session we were running 1/8 7014 on a/c on 3/8 plate. Machines are Idealarc A/C,D/C 250's, l just got one of these off Craigslist for $100.
- RocketSurgeon
That was how my class started. Safety lecture>O/A torch instruction (so you can cut your own coupons)> brief machine introduction>start welding.
It isn't a bad way to teach a craft that is "hands on". As long as the instructor can weld and knows how to pass a weld test (and having a CWI cert helps), they should pass that on to you in the booth. If you feel you need more oversight, don't hesitate to speak up. I was a bit lost and nervous my first few nights, but I made sure to get his input as I progressed. As much as I could without being an interruption to the other students.
Hopefully, your instructor should catch on your your speed of learning and help you at your pace and not to the curriculum pace.
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
sedanman
- sedanman
There are 5 students. If l were the instructor, l would have stopped by each booth and observed each student. We were told there would be no classroom time at all. I understand that seat time is important but a little theory goes a long way.
- RocketSurgeon
Is he not checking in with each of you at all?
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
Where in NY are you? I am by far not the best stick welder, but I would be happy to have you over and watch you burn rods for a couple of hours and compare notes. I am in CT near waterbury.
Multimatic 255
sedanman
- sedanman
Here's a pad of beads l did last night. I have covered 3 coupons this size both sides in 2 sessions. I am making use of seat time. Most of these were 7014 then l took the plunge and tried some 7018, a little more difficult to initiate an arc but I'll get it . I need to work on filling the crater at the end of my beads and l know they're not stacked perfectly but here for your viewing pleasure..........
- 20160519_072344.jpg (61.31 KiB) Viewed 12271 times
sedanman
- sedanman
I tried switching direction, didn't work well so l stopped. I will spens a lot of time working with my non dominant hand next time as this is something that must be done. The beads appear to switch direction on this pad because I started in the center of a warped plate to see if l could pull it flat, worked quite well. There are also tie-ins about every third bead, I'm burning every rod down to about 1 1/2 inch. Other students are dropping rods that aren't long enough to make a full pass. I figure tie-ins are part of the process so I better practice them
- RocketSurgeon
Looking real good! Don't worry about trying to do everything the first week. One step at a time.sedanman wrote:I tried switching direction, didn't work well so l stopped. I will spens a lot of time working with my non dominant hand next time as this is something that must be done. The beads appear to switch direction on this pad because I started in the center of a warped plate to see if l could pull it flat, worked quite well. There are also tie-ins about every third bead, I'm burning every rod down to about 1 1/2 inch. Other students are dropping rods that aren't long enough to make a full pass. I figure tie-ins are part of the process so I better practice them
When you end the bead and still have plenty of rod left (especially 7018), take the rod out of the stinger and tap the end to remove the excess flux. It helps with restart of the rod and you are less likely to have scorch marks on the work.
(Honestly, your first pad looks better than my first.)
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
- RocketSurgeon
Looking good! Keep at it!
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
Return to “Education Opportunities”
