mpete53
    Sun Mar 06, 2016 11:33 am
    New York
Holding small pieces at odd angles has always been a problem for me. I am have made a proof of concept magnetic fitting for a magnetic dial indicator holder. While the one I made was on a 3D printer is very heat sensitive it does work. Just some food for thought one of you may find a better way to do it.
IMG_4561 r.jpg (52.2 KiB) Viewed 937 times
Depending upon the strength of the magnet (and its proximity to the weld) it can aggravate a TIG arc in my experience. Might not be such a problem for a quick tack though.
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
i usually use the strong hand magtabs.
mpete53
    New York
I have the stronghand magtabs and the work fine most of the time, but this is gust another option.
BillE.Dee
    Mon Nov 27, 2017 8:53 pm
As Cj stated, magnets interfere with tig welding and I've had magnets interfere with mig welding. When I need extra hands, I use a "third hand" that I put together using a connecting rod from Caterpillar engine and pieces of 1/4 inch round stock. Nothing fancy but gives me that extra support.
Coldman
    Mon Dec 15, 2014 2:16 am
    Oz
Magnets do interfere with the arc but it's kinda fun to drag the arc back to where you need to tack.
